Bbox3 Sagem Tool
vivanco2020
Re: Bbox3 Sagem Tool
Berichtdoor vivanco2020 » 16 Apr 2020, 09:23
Hello everybody,
who can change my profile?
I do not know where I can complain to Proximus.
Because I actually have to have more speed.
565 meters normal must be at least 50 Mbits
Laatst gewijzigd door philippe_d op 16 Apr 2020, 10:52, 1 keer totaal gewijzigd.
Reden: url aangepast
Bedankt: 2761 keer
Recent bedankt: 15 keer
Uitgedeelde bedankjes: 753 keer
Contact:
Berichtdoor philippe_d » 16 Apr 2020, 10:46
There is nothing to complain about :wink: .
Your profile is based on some strict rules (set by Proximus), and your line is monitored frequently to check whether an increase is possible, or a decrease is needed (DLM process) ...
Based on the distance, it looks like you are in “zone 2”
But unfortunately you are connected to a non-vectoring capable DSLAM (Ikanos) :-( .
As per table in this post:
    - the non-vectoring base profile for your distance would be 20/6 Mbps.
    - DLM could further increase the profile up to a (theoretical) maximum of 50/10 Mbps.
    - however your line is not capable to support this maximum, hence you have been put on 30/8 Mbps.
Based on the SNR (10 dB up/down), a further increase would put you in a borderline area of instability ...
I would rather prefer a stable connection @ 30/8 above a 35/10 connection with many errors and disconnects :wink: .
Only hope for improvement is waiting until Proximus converts your line to a vectoring capable DSLAM (Broadcom)
Modem/Router: Fritz!Box 7590 int, FW 07.20, profiel 100/35.
vivanco2020
Berichtdoor vivanco2020 » 16 Apr 2020, 12:04
Englisch
Ich habe geschaut und festgestellt warum auf unsere strasse kein VDSL anschluss. Wo kann ich bescheid sagen ob auf unsere straße auch VDSL anschluss gebaut werden soll. siehe Foto
I looked and found out why there was no VDSL connection on our street. Where can I say whether VDSL connection should be built on our street. see photo
I can not understand why there is no DSLAM cabinet on our street.
Bedankt: 2761 keer
Contact:
Berichtdoor philippe_d » 16 Apr 2020, 14:10
Sie können nicht alles verlangen: leben im schönsten Teil Belgiens und schnelles Internet haben :-D
Sie haben also VDSL2, aber keine Vektorisierung!
Ich denke, Ihr Internet kommt direkt von der Vermittlungsstelle oder "LEX" (Zentrale) 87RAE0, Burgstrasse 4730 Raeren.
Die im LEX enthaltenen DSLAMs unterstützen leider keine Vektorisierung :-( .
(vertaald)
Je kan niet alles hebben: in het mooiste stukje van België leven, en snel internet willen :-)
Hij heeft dus wel VDSL2, maar geen vectoring!
Waarschijnlijk krijgt hij zijn VDSL2 direct vanuit de LEX (87RAE0) in Raeren, en zoals we weten ondersteunen de DSLAM's in de LEX (nog) geen vectoring.
Bedankt: 185 keer
Berichtdoor Dizzy » 16 Apr 2020, 16:06
Wat een prachtig voorbeeld om visueel aan te geven tot wat voor technische problemen onze lintbebouwing leidt :lol:
M_016
Bedankt: 50 keer
Uitgedeelde bedankjes: 4 keer
Berichtdoor M_016 » 16 Apr 2020, 18:02
It's certainly the case / gilt mit Sicherheit
jackho
Bedankt: 276 keer
Berichtdoor jackho » 16 Apr 2020, 19:53
Es gibt noch keine vektorisierten Straßengewächshäuser und einige Lex mit integriertem ROP
Bedankt: 2761 keer
Contact:
Berichtdoor philippe_d » 16 Apr 2020, 20:20
Userbase goes multilingual :-D
jackho
Bedankt: 276 keer
Berichtdoor jackho » 16 Apr 2020, 21:43
wir schaffen das :-D
vivanco2020
Berichtdoor vivanco2020 » 17 Apr 2020, 14:21
Thanks for the answers.
So that means wait until we get Vectoring connection. I have lived since 2011 and my speed has never increased. I hope it will be soon.
bartman
Bedankt: 24 keer
Berichtdoor bartman » 29 Apr 2020, 00:34
Hierbij mijn waarden gemeten vanop een win10 laptop geconnecteerd via wifi met de bbox3 modem. De max bit rate is dat te halen met een netwerkkabel?Afbeelding
Verstuurd vanaf mijn SM-G973F met Tapatalk
pluim
Bedankt: 9 keer
Berichtdoor pluim » 29 Apr 2020, 08:21
bartman schreef:De max bit rate is dat te halen met een netwerkkabel?
Nee, de max bitrate is in principe 'de max' dat je lijn kan hebben (waarvan je meestal een stukje minder krijgt om stabiliteit te garanderen).
De current bitrate is waaraan je synct, 70/30 in jouw geval. Dat is dus de maximum dat je zal krijgen, tenzij je abonnement dit verder beperkt natuurlijk. Zelf met dit profiel heb je met Proximus Internet Start of Scarlet Trio bijvoorbeeld een lagere snelheid. De volle snelheid van je profiel haal je met een provider als EDPnet (met het XL-abonnement).
Ik denk wel dat jouw snelheid nog omhoogkan, maar merk ook dat de modem nog niet lang aan staat. In zo'n gevallen gaat het vanzelf omhoog wanneer er gedetecteerd wordt dat je lijn perfect stabiel blijft met een hogere snelheid - volgens hoe ik het begrijp. ;)
An easily-interested brunette who loves to explore the unfamiliar :curt:
alloja
Bedankt: 32 keer
Berichtdoor alloja » 29 Apr 2020, 10:19
@vivanco: Dann sind zwei Alternativen möglich:
- die 4G-Abdeckung korrekt ist und dann durchgehen (Mobilus 5G Unlimited bei Proximus, Flybox bei Orange oder Tadaam bei Telenet);
- oder noch einfacher: das Koaxialkabel über Voo oder Orange.
Proximus Flex (100/35, b-box 3v+, V7, V5, Apple TV 4K) • Voo DVB-C • Fransat • Vu+ Ultimo 4K (DVB-C FBC + DVB-S2X FBC) • Vu+ Duo² (Dual DVB-T2) • Sat: 39°E<>15°W
vivanco2020
Berichtdoor vivanco2020 » 30 Apr 2020, 13:53
Thank you. I'm still looking at half a year and then I look at which provider is better for me.
Kioxkabel is not with me.
bartman
Bedankt: 24 keer
Berichtdoor bartman » 03 Mei 2020, 11:13
de tool werkt (zowel via laptop (draadloos) als via desktop (bedraad) maar krijg wel deze melding. IK draai op beide toestellen de laatste win 10 home
payphoneuser
Bedankt: 17 keer
Berichtdoor payphoneuser » 04 Mei 2020, 10:57
Uitvoeren als Administrator, dat lost het op
Sinna
Bedankt: 130 keer
Uitgedeelde bedankjes: 143 keer
Berichtdoor Sinna » 04 Mei 2020, 11:23
Adminrechten zijn m.i. niet nodig. Ik vermoed dat als je de tool vanuit een 'normale' folder lanceert (dus niet C:\Windows\System32) het wel zal lukken.
res
Berichtdoor res » 16 Mei 2020, 18:52
wat kan beter ?
Sinna
Bedankt: 130 keer
Berichtdoor Sinna » 16 Mei 2020, 19:17
Geduld oefenen al lijkt het maximum op de upload wel bereikt.
Sergewhotry
Berichtdoor Sergewhotry » 20 Mei 2020, 11:54
Bonjour,
Pour moi, avec le user et le mot de passe du modem, le même utilisé pour acceder aux options de ma Bbox 3, impossible de me connecter, je reçois toujours un message d'erreur.
D'avance merci.
alloja
Bedankt: 32 keer
Berichtdoor alloja » 20 Mei 2020, 12:53
Peut-être as-tu une b-box 3 Technicolor ? (C’est marqué sur la grande étiquette blanche à l’arrière de la b-box 3.) Si tel est le cas, le programme est alors incompatible…
Misschien heb je een b-box 3 Technicolor? (Het is gemarkeerd op het grote witte label op de achterkant van de b-box 3.) Als dat zo is, dan is het programma niet compatibel...
marethari
Berichtdoor marethari » 22 Mei 2020, 10:42
[code]
B-Box 3 Sagem Tool v0.13.0
Device:                        B-Box 3 Sagem
Downstream current bit rate:   69,999 kbps
Upstream current bit rate:     30,434 kbps
Downstream max bit rate:       83,971 kbps
Upstream max bit rate:         36,369 kbps
Downstream attenuation:        14.6 dB
Downstream noise margin:       10.7 dB
Upstream noise margin:         9.3 dB
Vectoring down:                yes
Vectoring up:                  yes
Modem vectoring compatible:    yes
ROP vectoring compatible:      yes
DSL standard:                  VDSL2 Annex B
DSL profile:                   17a
Estimated distance:            344 m
Proximus profile name:         70/30
Proximus DLM profile:          no
Proximus repair profile:       no
[/code]
enige kans dat ik meer krijg dan dit?
alloja
Bedankt: 32 keer
Berichtdoor alloja » 22 Mei 2020, 11:59
In deze configuratie lijkt het moeilijk om over te schakelen naar een hoger profiel...
Garpenlov
Bedankt: 21 keer
Berichtdoor Garpenlov » 22 Mei 2020, 12:55
Ik zal mijn lijnwaarde er ook maar eens opgooien dan zekers? :D
Ik heb een 100/40 abbo, ik hoop dat ik met de huidige lijnwaarde kans maak op 100/35.
Het is een kleine week geleden sinds de dlm em verhoogd heeft naar 85/35
Downstream current bit rate:   85,000 kbps
Upstream current bit rate:     35,000 kbps
Downstream max bit rate:       114,015 kbps
Upstream max bit rate:         40,565 kbps
Downstream attenuation:        16.4 dB
Downstream noise margin:       15.9 dB
Upstream noise margin:         9.1 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
Estimated distance:            414 m
Proximus profile name:         85/35
Proximus DLM profile:          yes
ISP: EDPnet XL 100/35. (Fritz 7530 & edgerouter 6p)
Mobiel: Orange cheetah (Xiaomi 9t pro)
M_016
Bedankt: 50 keer
Berichtdoor M_016 » 22 Mei 2020, 15:06
@Garpenlov die kans op 100/35 is reëel gezien de noise margin waarden (>10 dB) maar er is uiteraard geen garantie de DLM-wegen zijn soms nogal ondoorgrondelijk
jackho
Bedankt: 276 keer
Berichtdoor jackho » 22 Mei 2020, 17:11
Soms moet er ook een grondige opsporing gebeuren door Proximus waarom er zelfs met heel goede waarden geen verhoging mogelijk is!
Jelly
Bedankt: 16 keer
Contact:
Berichtdoor Jelly » 24 Mei 2020, 20:03
Na al die jaren Coax en wegens een verhuis toch maar eens de sprong gewaagd naar de VDSL technologie.
Valse start bij installatie, nieuwe kabel die de woning binnen kwam was beschadigd en moest hersteld worden door Proximus, al schrik voor teleurstellende lijnwaarden. Herstelling ziet er momenteel wel succesvol uit:
Downstream current bit rate: 69 999 kbps
Upstream current bit rate: 29 999 kbps
Downstream max bit rate: 137 256 kbps
Upstream max bit rate: 42 782 kbps
Downstream attenuation: 7,5 dB
Downstream noise margin: 29,2 dB
Upstream noise margin: 14,4 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Estimated distance: 121 m
Op dit ogenblik ontvang ik van Proximus (speedtest en via MyProximus) een 60mbps down en 18 mbps up. Iemand een idee waarom er niet onmiddellijk 70/30 wordt aangeboden?
Ik ben Internet Maxi klant. Wanneer alles stabiel is volgt nog de overstap naar EDPnet. Gezien de huidige waarde vermoed ik wel dat een 100/35 mogelijk is.
Everything that has a beginning has an end.
Patje
Bedankt: 75 keer
Berichtdoor Patje » 24 Mei 2020, 20:08
Internet Maxi is 20 Mbps upload, dus meer zal je niet krijgen ondanks je synct op 30 of 35 :)
Je zit blijkbaar wel op een 70 down die kan verhogen naar 100
Intel® i3-4150 Dual-Core @3,5 GHZ. Ram: 16 GB. HD 1 TB || Windows 10 Home X64 || GSM Huawei Y6 (2019) @Proximus FlexPack
Afbeelding Afbeelding
*B-Box3V+ Speedtest https://www.speedtest.net/result/9814493578
Jelly
Bedankt: 16 keer
Contact:
Berichtdoor Jelly » 24 Mei 2020, 20:30
Dat snap ik Patje
Vind het gewoon vreemd dat ik via my Proximus een snelheid krijg van 58 en 18up in plaats van huidige sync en abonnement 70 down 20 up.
Mvg
M_016
Bedankt: 50 keer
Berichtdoor M_016 » 25 Mei 2020, 10:53
@jelly dit lijkt inderdaad vreemd vermits onderstaande uw lijnstartprofiel is (en blijkbaar niet gewijzigd werd)
-> even = een paar dagen aanzien en Proximus contacteren of eventueel 0800 22424 bellen met uw klantnr ter hand (= machine/applicatie)
de speedtest werd toch via utp-kabel uitgevoerd (en niet win WiFi 2.4)?
alloja
Bedankt: 32 keer
Berichtdoor alloja » 25 Mei 2020, 11:54
Een synchronisatie van 70 Mbps geeft meestal een maximale snelheid van 63 Mbps. Het is mij altijd uitgelegd dat je ±10% moet verwijderen tussen de synchronisatie en de werkelijke maximumsnelheid.
Dus, zoals M_016 zegt, afhankelijk van hoe de snelheidstest werd uitgevoerd, kan er een verlies van een paar Mbps zijn als het werd gedaan in Wi-Fi of met een tussenliggend apparaat tussen de b-box en de PC.
trical
Berichtdoor trical » 29 Mei 2020, 10:22
Downstream current bit rate:   70.417 kbps
Upstream current bit rate:     19.999 kbps
Downstream max bit rate:       88.945 kbps
Upstream max bit rate:         22.864 kbps
Downstream attenuation:        19,4 dB
Downstream noise margin:       12,3 dB
Upstream noise margin:         7,1 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
Estimated distance:            516 m
Proximus profile name:         70/20
dit is op edpnet
dupondje
Bedankt: 11 keer
Berichtdoor dupondje » 29 Mei 2020, 15:59
Werkt de BBOX tool eigenlijk op een BBOX 3v+?
Helaas niet te testen hier op een Linux PC, moet dringend eens kijken om de tool te porteren naar een andere taal :)
alloja
Bedankt: 32 keer
Berichtdoor alloja » 29 Mei 2020, 17:32
dupondje schreef:Werkt de BBOX tool eigenlijk op een BBOX 3v+?
Alle b-box 3v+ zijn Sagemcom modellen. Dus, geen zorgen.
GuntherDW
Bedankt: 61 keer
Contact:
Berichtdoor GuntherDW » 29 Mei 2020, 17:44
Dat het met mono niet werkt klopt, er zitten bepaalde dingen in die net iets anders werken.
Echter kan je met winetricks wel de "echte" .net installeren geloof ik welke deze tool gebruikt?
Desnoods in een andere wine root folder, of via playonlinux/lutris/... om je "echte" niet te "vervuilen"?
Heb dit zelf nog niet geprobeerd omdat ik de modems welke deze tool gebruikt niet heb maar heb wel al gechecked waarom het niet draait op linux.
hardyscript
Bedankt: 29 keer
Uitgedeelde bedankjes: 299 keer
Contact:
Berichtdoor hardyscript » 11 Jul 2020, 11:36
Kan iemand van jullie mij vertellen of er verbetering mogelijk is op mijn lijn en welke stappen ik moet ondernemen?
Upstream current bit rate:     35 000 kbps
Downstream max bit rate:       109 138 kbps
Upstream max bit rate:         41 340 kbps
Downstream attenuation:        17,9 dB
Downstream noise margin:       19,4 dB
Upstream noise margin:         9,8 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
Estimated distance:            450 m
Proximus profile name:         70/35
EotT
Bedankt: 110 keer
Berichtdoor EotT » 11 Jul 2020, 11:52
DLM zal jouw lijn waarschijnlijk nog wel verhogen naar 85/35. Hiervoor moet je niks doen, gewoon geduld hebben. 100/35 zal waarschijnlijk niet lukken denk ik.
hardyscript
Bedankt: 29 keer
Contact:
Berichtdoor hardyscript » 11 Jul 2020, 11:57
EotT schreef:DLM zal jouw lijn waarschijnlijk nog wel verhogen naar 85/35. Hiervoor moet je niks doen, gewoon geduld hebben. 100/35 zal waarschijnlijk niet lukken denk ik.
Ik stond vroeger op 85/35 maar sinds nieuwe buren ben ik gezakt naar 70 profiel. zou een lijntest iets uithalen?
M_016
Bedankt: 50 keer
Berichtdoor M_016 » 11 Jul 2020, 15:41
Ik vermoed dat u best even geduld oefent. Uw lijn is mogelijk teruggevallen op zijn startdebiet 70/30 omwille van een technische interventie op de distributiekabel voor de aansluiting van uw nieuwe buren en ondertussen op een DLM-profiel 70/35 gebracht op basis van resultaten van automatisch lopende tests.
Vermits de noise margin down >> 10 dB is de kans op terug 85/35 mijns inziens inderdaad zeker reëel
Patje
Bedankt: 75 keer
Berichtdoor Patje » 11 Jul 2020, 16:11
Volgens mij is die start debiet niet 70 maar 50 als men in zone 2 zit (zijn afstand meting is 450m) , maar de lijn zou in principe wel moeten 85 Mbps aankunnen.
